please help
Old 04-18-2008, 10:33 PM
mn roamer's Avatar
mn roamer
mn roamer is offline
Default please help
what does b.u.s error mean 2007 street bob just putting on my new tins and pc 111 and that came on please help
Old 04-18-2008, 10:58 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
Default RE: please help
man i wish i can help you i have never seen tht code... maybe if you runa diagnostic it will give you a bit more... here is how to do that and the code read out
[font="times new roman"][size=3]1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range
and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module)
to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module (EFI) / (Ignition Control Module, 'Carbureted')
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC’s the code will be
displayed or the word “none” will appear if there are no DTC’s. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up.
Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 9.
If the code is current it will reappear.
9 – Press and release the odometer reset button to continue to the next module.
10 – Turn Ignition switch to OFF.
DTC FAULT CONDITION MODULE
B0563 Battery Voltage High TSM/TSSM
B1004 Fuel Level Sending Unit Low Instruments
B1005 Fuel Level Sending Unit High/Open Instruments
B1006 Accessory Line Overvoltage Instruments
B1007 Ignition Line Overvoltage Instruments
B1008 Reset Switch Closed Instruments
B1131 Alarm Output Low TSM/TSSM
B1132 Alarm Output High TSM/TSSM
B1134 Starter Output High TSM/TSSM
B1135 Accelerometer Fault TSM/TSSM
B1151 Sidecar BAS Low TSM/TSSM
B1152 Sidecar BAS High TSM/TSSM
B1153 Sidecar BAS Out of Range TSM/TSSM
P0106 MAP Sensor Rate of Range Error Carb
P0107 Map Sensor Failed Open/Low Carb
P0107 Map Sensor Open/Low EFI
P0108 Map Sensor Failed High Carb
P0108 Map Sensor High EFI
P0112 IAT Sensor Voltage Low EFI
P0113 IAT Sensor Voltage Open/High EFI
P0117 ET Sensor Voltage Low EFI
P0118 ET Sensor Voltage Open/High EFI
P0122 TP Sensor Open/Low EFI
P0123 TP Sensor High EFI
P0261 Front Injector Open/Low EFI
P0262 Front Injector High EFI
P0263 Rear Injector Open/Low EFI
P0264 Rear Injector High EFI
P0373 CKP Sensor Intermittent Carb
P0373 CKP Sensor Intermittent EFI
P0374 CKP Sensor Not Detected Carb
P0374 CKP Sensor Synch Error EFI
P0501 VSS Low Carb
P0501 VSS Low EFI
P0502 VSS High/Open Carb
P0502 VSS High/Open EFI
P0505 Loss of Idle Sped Control EFI
P0562 Battery Voltage Low Carb
P0562 Battery Voltage Low EFI
P0563 Battery Voltage High Carb
P0563 Battery Voltage High EFI
P0602 Calibration Memory Error Carb
P0603 EEPROM Failure Carb
P0603 ECM EEPROM Error EFI
P0604 RAM Failure Carb
P0605 Program Memory Error Carb
P0605 ECM Flash Error EFI
P0607 Converter Error Carb
P1001 System Relay Coil Open/Low EFI
P1002 System rel
Old 04-18-2008, 11:23 PM
mn roamer's Avatar
mn roamer
thanks very much joe
Old 04-19-2008, 12:45 AM
JRK5892's Avatar
JRK5892
JRK5892 is offline
anytime brother... post up what you get and we can help you shoot though that
Old 04-19-2008, 07:33 AM
mn roamer's Avatar
mn roamer
i pinched the plug for harley to hook up too between the back of fuse panle and the middle bolt. when i ran the bolt in it cut the wires cause it to ground out was a bad ignition fuse that gave it away
ps ty again i have been a member of this form for awhile dont chim in much just read alot but now its all done took 2 hours to find [:@]now i can get my first ride of the year in today live in minnesota so weather just starting to get nice
Old 04-19-2008, 09:54 AM
up in minot's Avatar
up in minot
up in minot is offline
After some research, it appears that your error code = "BUS Er" Serial data bus shorted/low/open/high
Hopefully this helps some how...
Old 04-19-2008, 12:27 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
glad you got it worked out!
51Moe
09-07-2008 11:51 PM
crossy
08-12-2007 10:07 PM
Nasty Nightster
General Topics/Tech Tips
06-11-2007 01:39 PM
vailtl
05-14-2007 04:34 PM
tripl8
06-04-2006 11:51 PM
Quick Reply: please help
