Dyna Wide Tire Kit
RE: Dyna Wide Tire Kit
It is the tire, two tie wraps, two bolts (rounded heads) and two new wire struts....you could probrably get by without it.
What I would do now is get the instructions...you can then see the parts that come in the kit and then order them separate from Zanonitti for about $30 bucks and purchase the the tire.
ORIGINAL: beerman522
Has anyone bought the Dyna Wide Tire Kit that HD sells for 265.00
and if so what -besides the SE 180 tire-
is in the kit and do you really need the whole kit??
I have heard that all that one needs is to purchase the tire
and mount it with no problems
Have a look here -
https://www.hdforums.com/fb.asp?m=3075591
(courtesy of Dynaflyer)
"purchase the tire and mount it with no problems"
No problems, as long as you pay attention to wire routing.
mud
you can definitely install the 180 without the kit.... i just put mine all back together, yesterday....the directional wires are close, but no problems at all.... i had it out all day yesterday- and on some rough roads, too- and no issues....just make sure your wires are pulled tight against the fender
i'm thinking i just might get the kit, anyway.... maybe install it on a rainy day just for some assurance, you know.... i do like the "wire channel" idea
....and i haven't really done any dipping around on the tire, so i can't account for any real difference in performance...but it does look bad-azz
ORIGINAL: 2wheeler
Is there any noticeable difference in handling with the wider tire? Wondering about the interplay with the narrow front tire? Sure looks good.
[IMG]local://upfiles/16528/D30DD7C805814A98997715E6B4C49857.jpg[/IMG]
creep1
05-15-2010 07:03 AM
