changing front fork springs
Old 05-16-2008, 08:04 AM
tazmister's Avatar
tazmister
tazmister is offline
Default changing front fork springs
I want to change the front springs on my Dyna what is the easiest way to do it?
Old 05-16-2008, 08:28 AM
Shrug's Avatar
Shrug
Shrug is offline
Default RE: changing front fork springs
I did mine on the bike after changing the sliders to chrome.
[ol][*]Start with the service manual.[*]Jack it up.[*]Remove the fork tube bolts at the top (carefully, they will shoot across the room).[*]Remove and replace.[/ol]
If you're changing oil, you'll have to remove the front wheel and then the forks from the clamps. Don't forget to compress and extend the forks a few times when you add new oil.
You'll probably need two people to replace the fork tube bolts.
Old 05-16-2008, 10:08 AM
thrillseeker's Avatar
thrillseeker
thrillseeker is offline
best route is to buy the service manual and follow the procedure. Scott outlined it pretty accurately, but having the SM gives you pictures, proper order of things, torque spec's, etc
Old 05-16-2008, 10:12 AM
Desert Hog's Avatar
Desert Hog
Desert Hog is offline
Easiest way is to drop it of at a local Indy
Best way is to follow KTM Scott's directions. It is really easy once the front end is in the air. I recommend breaking the bolts loose while it is on the ground though.
Old 05-16-2008, 10:23 AM
the metal's Avatar
the metal
the metal is offline
it's true about the heavy *** top bolt taking flight.for me,it usually dings a riser, then flies straight up and lands back down on the gas tank, bouncing a couple times.
i learned to put a shop rag across the bolt/wrench and have someone hold that whilst i twist it loose
Old 05-16-2008, 03:42 PM
mikedmeyer's Avatar
mikedmeyer
mikedmeyer is offline
The best way to do it is to put in some cartridge emulators instead.
Old 05-19-2008, 02:15 PM
tazmister's Avatar
tazmister
thanks Bros I'll get a bro to give me a hand
Old 05-19-2008, 03:07 PM
Righteous's Avatar
Righteous
Righteous is offline
Would you still suggest keeping the forks on the trees if you are putting a lowering kit on it? To get the additional spring underneath the seat pipe, you have to remove the bolt at the bottom of the slider and pull the seat pipe out through the top. Can you do this while the forks are on the bike? Or, should you just go ahead and remove them. I'm going to be installing a Progressive lowering kit this weekend, so I really need to know.
Old 05-19-2008, 03:08 PM
Righteous's Avatar
Righteous
Forgot to subscribe.
Old 05-19-2008, 03:48 PM
reded's Avatar
reded
reded is offline
Watch thatsharp a$$ piece of tubing on top of the spring when taking the fork caps off and putting them back on. Damn near cut my finger off on one last weekend.
ADVNTR
2014-2023 Touring Models
25
01-17-2017 07:37 AM
cerelious
06-20-2015 03:11 PM
ynots
08-18-2011 12:00 AM
hell hound
01-16-2010 04:35 PM
JonnyD
05-27-2009 08:20 PM
Quick Reply: changing front fork springs
