Starter relay
Old 05-19-2008, 04:01 AM
hogwild72's Avatar
hogwild72
hogwild72 is offline
6th Gear
Default Starter relay
[:@]Got a question about the starter relays, I go through 3 relays per summer is that the norm or a bit much. I have checked all the connections and have a new battery and even cleaned the pins on the relay itself. I press the starter button it does nothing, if I have the patients you can keep pressing the button and hopefully I don’t release before if fires or I just change out the relay and it fires up.
Old 05-19-2008, 06:12 PM
HD7585's Avatar
HD7585
HD7585 is offline
Default RE: Starter relay
The relay might not be getting a full 12 volt shot from the start switch, or the ground is weak. Both of these will burn the contacts. Then when you install a new relay the contacts are fresh and will work till they become burnt over time. [&:]
Old 05-19-2008, 06:30 PM
wescoot2's Avatar
wescoot2
wescoot2 is offline
3 Relays ?? per summer ???
I have 63K miles on an 01 Wide GLide, and haven't gone thru 1.......
I'd say ya have a problem which needs to be addressed.
Respects,
Ed
Old 05-21-2008, 09:17 AM
hogwild72's Avatar
hogwild72
6th Gear
I agree, that’s why I was wondering if anyone else had that issue, the dealer in Alaska said they always go out when I went in there to by a replacement. So now I carry 2 extra.
Old 05-21-2008, 12:01 PM
LowriderT's Avatar
LowriderT
LowriderT is offline
The relay on the starter itself or the fuse ?
Old 05-22-2008, 03:19 AM
hogwild72's Avatar
hogwild72
6th Gear
I’m guessing you are referring to it as the fuse, its located on the right side under the seat with the fuses 1x1x1/2 inch, and 5 prongs. They are only about $6 but it just a beginning to be a pain.
Old 05-24-2008, 05:30 PM
LowriderT's Avatar
LowriderT
Yes I ment to say starter relay..not fuse but thats what it looks like to me. I have had mine go out not to long ago. It has only happened one time but I did get a spare so if it happened again I'm covered. Never did find out why my blew. Have you asked the dealer service what causes it?
Old 05-24-2008, 05:38 PM
mccalljv's Avatar
mccalljv
mccalljv is offline
ORIGINAL: HD7585
+1
Something is makeing the contacts in the relay burn up... Not sure what, maybe too much current draw from the starter, so check thator like HD7585 said, bad ground somewhere along the path. Regardless of what your dealer says it's not normal for relays to go bad that fast.
RavenRider03
General Topics/Tech Tips
05-24-2016 04:45 AM
NB Biker
08-23-2014 06:54 AM
tom301
03-10-2012 07:37 PM
wildbillXIII
10-22-2009 10:40 AM
Beauregard
06-02-2009 08:29 PM
Quick Reply: Starter relay
