how to make dyna faster?
RE: how to make dyna faster?
ORIGINAL: billy07011@yahoo.com
I have a 2008 dyna superglide custom what are the best ways to make the bike faster and more peppy?
Start with a Stage 1....peppy
Then just because...Stage 2...fast
Addiction has set in...Stage 3..Real Fast and Peppy!
I almost forgot, paint it Black!
Faster
Grew up on big jap bikes so when I bought my 08 FXSTC and took it for a spin I thought I would die it was such a dog. Bad news, lots of money to fix. Good news, add a hyper charger, master tuner, Rush ceramic coated true dual exhaust, 106 S&S pistons, 580 S&S compression relief cams, 50 mm throttle body with Screaming Eagle injectors, Screaming Eagle compression heads that have been ported and polished, a 30 tooth Andrews primary drive pulley, and a great mechanic, and you should have all you need. Over 90 HP and 107 torque. Unfortunately as others have stated, you need to spend about $8000.00 but its worth it cause NOTHIN sounds or looks like a Harley. Ride strong my friends.
I had the 103" build done to mine along with stage lll upgrades and some of the stuff you mentioned above to include a 2 into 1 Bassani Road Rage pipes, dynoed all for about $3,500 at our local dealership this past summer.
My numbers are 105 hp 107 tq.
If you truly spent $8K on the above you got ripped BIG time! For $8K you could have gotten the HD 120R Race Engine that puts out over 140 HP and still have a lot of change left over for other upgrades.
