5000 mile service
Old 06-05-2008, 10:10 PM
firestop52's Avatar
firestop52
firestop52 is offline
Default 5000 mile service
Do I need to have the 5000 mils service done by the dealer? I have changed the fluids and done all the regular maintence. Do they do something more? Thanks
[IMG]local://upfiles/41831/A45E447D9C214428B1CF9935840DBA25.jpg[/IMG]
Old 06-05-2008, 10:39 PM
Bluesrider's Avatar
Bluesrider
Bluesrider is offline
Default RE: 5000 mile service
I don't think so. I just did mine and if I were were you, I would get the manual and do your own service. The dealer pricing on service is just not worth it. You can learn a lot about what you are riding and thats a good thing.
Old 06-05-2008, 10:44 PM
firestop52's Avatar
firestop52
That is what I figured, I didn't realize it was in the service manual. I guess I need to look at mine. Thanks
Old 06-05-2008, 11:46 PM
OhioSkully's Avatar
OhioSkully
OhioSkully is offline
AT 5,000 MILES / 8,000 KILOMETERS
ITEM SERVICED
PROCEDURE
NOTES
Engine oil and filter
Replace
Air cleaner
Inspect, service as required
Tires
Check pressure, inspect tread
Wheel spokes
Check tightness
1,2
Clutch
Check adjustment
Rear belt and sprockets
Inspect, adjust belt
Throttle, brake and clutch controls
Check, adjust and lubricate
Fuel, lines and fittings
Inspect for leaks
Brake fluid
Check levels and condition
Brake pads and discs
Inspect for wear
Spark plugs
Inspect
Electrical equipment and switches
Check operation
Front fork oil
Replace every 50,000 miles (80,000 kilometers)
Rear fork bearings
Inspect every 30,000 miles (48,000 kilometers)
Road test
Verify component and system functions
Old 06-05-2008, 11:50 PM
OhioSkully's Avatar
OhioSkully
https://www.harley-davidson.com/EX/M...bmLocale=en_US
&nbsp\\;
that list comes from the harley website click above enter your vin and mileage and you get a list.
&nbsp\\;
the list is also in your owners manual and if you go and buy a service manual it will show you how to do it all.
Old 06-05-2008, 11:53 PM
OhioSkully's Avatar
OhioSkully
AT 20,000 MILES / 32,000 KILOMETERS
ITEM SERVICED
PROCEDURE
NOTES
Replace
Air cleaner
Tires
Wheel spokes
Check tightness
1,3
Primary chaincase lubricant
Replace
Transmission lubricant
Replace
Clutch
Check adjustment
Jiffy stand
Inspect and lubricate
Inspect for leaks
Brake fluid
Inspect for wear
Spark plugs
Inspect
Spark plugs
Replace
Check operation
Front fork oil
Steering head bearings
Adjust
1,2
Rear fork bearings
Critical fasteners
Check tightness
Engine mounts and stabilizer links
Inspect
Road test
Old 06-05-2008, 11:54 PM
OhioSkully's Avatar
OhioSkully
AT 10,000 MILES / 16,000 KILOMETERS
ITEM SERVICED
PROCEDURE
NOTES
Replace
Air cleaner
Tires
Replace
Clutch
Check adjustment
Jiffy stand
Inspect for leaks
Brake fluid
Inspect for wear
Spark plugs
Inspect
Check operation
Front fork oil
Adjust
1,2
Rear fork bearings
Critical fasteners
Check tightness
Inspect
Road test
NOTES
1. Should be performed by an authorized Harley-Davidson dealer, unless you have the proper tools, service data and are mechanically qualified
2. Disassemble, lubricate and inspect every 30,000 miles (48,000 kilometers)
3. Replace D.O.T. 4 HYDRAULIC BRAKE FLUID and flush system every two (2) years
Old 06-06-2008, 02:38 AM
SK8ROD's Avatar
SK8ROD
SK8ROD is offline
its difficult to see the need for ever getting the bike serviced at a dealer&nbsp\\;&nbsp\\; thing is , as i never intend to sell my scoot, then i dont need to worry about the dealer stamp on the book affecting price and i prefer to work on my own machine, you know its done right then...
Old 06-06-2008, 08:40 AM
glide05's Avatar
glide05
glide05 is offline
OK - you have a list - and it's not difficult.
Maybe I'm a bit **** - but when I do mine - I take pictures along the way.
Take a pic of the speedo - with mileage ... if something needs "inspecting" - brakes, tires, etc - take pics of each.
Older models need the primary chain adjusted - take a pic of how you did it.&nbsp\\; Same goes for the drive belt.
Take a pic of all raw materials (filter, oil, etc).
This adds minimal time to the task - and in the end you crack a beer - dump the pics to your computer - put them in a document - with a few notes - then print it out.
It's a great reference for yourself - and if anyone ever questions it - well - you have a much better document than the dealer gives you!&nbsp\\; If you have to resell - anyone would be impressed that you took care of the bike and paid great attention to detail.
Old 06-06-2008, 01:29 PM
Punty's Avatar
Punty
Punty is offline
ORIGINAL: OhioSkully
ITEM SERVICED
PROCEDURE
NOTES
Replace
Air cleaner
Tires
Wheel spokes
Check tightness
1,2
Clutch
Check adjustment
Inspect for leaks
Brake fluid
Inspect for wear
Spark plugs
Inspect
Check operation
Front fork oil
Rear fork bearings
Road test
&nbsp\\;
&nbsp\\;
This is about $550 at my local dealer, I cant see why anyone would pay it but..........
Quick Reply: 5000 mile service
