POWER COMMANDER SETTINGS
Old 07-02-2008, 11:11 PM
70mach1's Avatar
70mach1
70mach1 is offline
Default POWER COMMANDER SETTINGS
I installed pipes , AC , and a Power Commander on my 2007 Dyna Low Rider .
I havent realy played with it as far as the high , med. , or low settings are conserned .
I did reset the throttle position , but thats it ,
Anyone change the settings on the low med, or high buttons ?
Would I just click one and ride it a little then check my plugs or ???
&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&n bsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbs p\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\ \;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\; &nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&n bsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\; Thanks,,,,
Old 07-03-2008, 12:26 AM
PigInaBlanket's Avatar
PigInaBlanket
PigInaBlanket is offline
Default RE: POWER COMMANDER SETTINGS
look on page 2-27 of the instruction manual, if you don't have it you can download it from the power Commander site.
Those buttons are not really good for tuning just for general adjustments as they effect a whole range instead of precise settings. Anyways here is a screenshot of the instructions for the buttons...
Old 07-03-2008, 01:46 AM
SK8ROD's Avatar
SK8ROD
SK8ROD is offline
+1 Pig,,,, &nbsp\\; you need to hook up your laptop, you can swap maps, tweak them etc etc and enable rev extend plus the accelerator pump option. I have a map on mine i use for good gas mileage and a performance map,,&nbsp\\; you just cant do any of that sh#t without hooking up to a computer..
Mpc1177
07-01-2012 08:59 PM
amabeetle
04-10-2011 11:00 PM
palatium
01-21-2010 07:22 AM
FX4
04-04-2009 07:24 PM
skos
04-22-2005 01:06 AM
Quick Reply: POWER COMMANDER SETTINGS
