Oil Archive (no new posts) An archive of oil related questions and comments.
..one more post on OIL
  #661
Old 09-24-2014, 08:39 AM
maddghost's Avatar
maddghost
maddghost is offline
first rule - oil is oil, so don't buy into the hype.
second - If they have the right grade oil then use it if you like but at this point I will refer you back to rule #1 stated above.
IMHO unless your getting an incredibly good price on it stick to what you use now until this oil is proven worthy.
  #662
Old 09-24-2014, 11:41 AM
upflying's Avatar
upflying
upflying is online now
Received 25,991 Likes on 11,040 Posts
My number one rule on oil, buy whatever is on sale.
  #663
Old 09-24-2014, 06:57 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
seniorsuperglideE8 is offline
Received 4,281 Likes on 2,349 Posts
Oh no, I got suckered into an oil thread!
  #664
Old 09-24-2014, 07:45 PM
Suede Blue Man's Avatar
Suede Blue Man
Suede Blue Man is offline
"...I want synthetic oil
One that won't make me sick
One that won't make me crash my car
Or make me feel three feet thick
One that won't hurt my head
One that won't make my mouth too dry
Or make my eyes too red..."
It must have what cars crave!
  #665
Old 09-25-2014, 08:57 AM
dynawg1's Avatar
dynawg1
dynawg1 is offline
Originally Posted by e_minor_pentatonic
I use the same oil in my primary as in the motor - Mobile 1 syn. 20/50
The correct oil level is when the oil reaches the bottom of the clutch diaphragm spring. For my 88 it's usually about 26 oz.
No comment on Mobil 1, haven't used it, happy with Amsoil in the engine.
Minor is spot on about using exactly 26 ounces of oil in the primary - NOT a full quart as many on this thread have recommended.
According to the HD factory Service Manual for my 2000 Twin Cam Dyna Wideglide:
"The primary chaincase lubricant should be level with the bottom edge of the clutch diaphragm spring, approximately 26 oz. (768.9 ml)."
More from the HD factory manual:
"CAUTION: Do not overfill the primary chaincase with lubricant. Over-filling may cause rough clutch engagement, clutch drag and/or difficulty in finding neutral at engine idle."
I notice a lot of contributors here recommending adding a full quart of primary fluid. That is 6 oz (almost 25%) too much!! Makes me wonder if that has more to do with the complaints about rough shifting/clutch engagement than the type of oil used in the primary.
I just changed out the primary fluid in my 2000 Dyna WG (used B&M Quickshift non-synthetic), measured exactly 26 oz and confirmed that the fluid just touched the bottom of the clutch diaphragm spring with the bike level. Went for a long ride. The bike actually spun the rear tire (150 Metzeler) in second gear for the first time ever (30k miles on the odometer). I'm a believer!
Stop overfilling your primary! The right amount of fluid (only 26 oz.) made a big difference for me.
  #666
Old 03-22-2016, 07:33 AM
Cbb129's Avatar
Cbb129
Cbb129 is offline
Default What oils do you guys use ?
It's spring in New England, and time to change all the fluids in my '06 Dyna Super Glide. Just wondering what the general consensus is on oils in the crank, tranny and primary ?
  #667
Old 03-22-2016, 07:47 AM
joe40x's Avatar
joe40x
joe40x is online now
There is only about a thousand threads on this already...use the search function.
  #668
Old 03-22-2016, 08:19 AM
jricharc's Avatar
jricharc
jricharc is offline
I run Delo 400 15W40 in the Primary and engine.
  #669
Old 03-22-2016, 08:30 AM
TinCupChalice's Avatar
TinCupChalice
TinCupChalice is offline
Received 8,749 Likes on 3,962 Posts
You may have better luck asking how many angels can dance on the head of a pin
About all anyone can relate to you is what their experiences are. I've had great results with Redline V-Twin Transmission w/shockproof in the transmission, Mobil 1 Racing 4T 10w-40 synthetic in the primary and last season I was running LiquiMoly 10w-60 synthetic in the engine. Not sure if I'll go back to Vavoline VR1 SAE50 in the engine this summer but the LiquiMoly worked well in cooler temperaturers with none of the typical increase in top end noise...
  #670
Old 03-22-2016, 09:02 AM
hd4evr2008's Avatar
hd4evr2008
hd4evr2008 is offline
Received 1,814 Likes on 814 Posts
First.......you should have changed the oil BEFORE you put your bike away........
Anyway, you're gonna get all kinds of answers, but I've been using this combo for years, and it works well:
Mobil One V-Twin 20w-50 in the engine
Spectro Platinum 6-Speed in the tranny
HD Formula + in the primary
Quick Reply: ..one more post on OIL
