Oil Archive (no new posts) An archive of oil related questions and comments.
..one more post on OIL
Old 05-22-2016, 09:10 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,499 Likes on 4,612 Posts
Has anyone here ever seen a thread about premature wear/damage due to the brand of oil used, syn or conventional, in an engine or transmission???
Has anyone here ever worn out a transmission gear or bearing due to using motor oil in the transmission?
  #752
Old 05-22-2016, 09:31 AM
Warp Factor's Avatar
Warp Factor
Warp Factor is offline
Originally Posted by Warp Factor
Link? A lot of the sites I pull up are Amsoil sponsored sites, so if you've found something different, I'd like to take a look at it.
I found this report which involves some rather extensive testing, and easy to interpret results, although it was prepared for Amsoil, so I don't know whether that casts doubt on the findings or not.
http://americasoil.biz/files/g2156_A...cycle_Oils.pdf
  #753
Old 05-22-2016, 04:26 PM
newdyna's Avatar
newdyna
newdyna is offline
  #754
Old 05-22-2016, 04:48 PM
Warp Factor
Same study I linked to, with an affidavit on page 26 stating that it was prepared for Amsoil.
  #755
Old 05-22-2016, 08:38 PM
superslomo's Avatar
superslomo
superslomo is offline
Thanks. I just finished reading all of that report and there were some surprising results noted. Good read.
  #756
Old 05-23-2016, 02:31 AM
jumpinjoe313's Avatar
jumpinjoe313
jumpinjoe313 is offline
I guess this is as good a place as any to post this question so here goes .......
Did any of you who use a synthetic motor oil (any brand) in the crankcase notice the motor noises being any louder than with dino oil? I've heard from several they run the dino just for that reason, it's quieter. I would think it might be the same issue in either of the 3 holes. Whadaya say?
Thanks and regards, Joe.
  #757
Old 05-23-2016, 06:28 AM
HKMark23's Avatar
HKMark23
HKMark23 is offline
Received 1,934 Likes on 1,111 Posts
Yep, I'd have to agree. The ticking from the rockers is more noticeable for me. I plan on addressing that problem with a set of Rockout inserts, which IMHO are a good idea for the TC anyway.
This comment will draw flack, I'll bet, but eschewing any "clearly superior" synthetic oil on the basis of a "waxy" dino oil's ability to quiet things down is,,,, wrong thinking IMHO.
  #758
Old 05-23-2016, 09:36 AM
newdyna's Avatar
newdyna
newdyna is offline
Rather than just rant from a warped perspective, I have tried to go to other mfr sites to find THEIR oil specs, on both motor and gear oils. I have not found them all, however the ones I did find were pretty much in line with the "slanted study" done by a test facility for Amsoil. My mother used to tell me that if I had nothing nice to say, keep quiet.
  #759
Old 06-05-2017, 01:49 PM
Ellabella's Avatar
Ellabella
Ellabella is offline
Stage II
Default Oil Change
What oil and filter do I need for my 07 Ultra Classic? Also, is there an additive that needs to be added?
  #760
Old 06-05-2017, 02:29 PM
BuzzCap7's Avatar
BuzzCap7
BuzzCap7 is online now
Moderator
Received 18,341 Likes on 10,703 Posts
I would (and do) stick with the standard oil and oil filter that Harley sells.
No additive is needed.
And personally after a great deal of experience with both, their regular 20/50 is sufficient not the SYN3 for normal biker riding.
BuzzCap7
Quick Reply: ..one more post on OIL
