Internally wiring z bars, Need Help, tips or advice welcome.
Old 07-28-2008, 01:25 PM
ZeroFiveFour's Avatar
ZeroFiveFour
ZeroFiveFour is offline
Default Internally wiring z bars, Need Help, tips or advice welcome.
Need tips on pulling wires through. WD-40? any tips welcome, cant get the wires through atm. Thanks, Tom
Old 07-28-2008, 01:34 PM
fiend138's Avatar
fiend138
fiend138 is offline
Default RE: Internally wiring z bars, Need Help, tips or advice welcome.
Are you trying to get them through one at a time?
Old 07-28-2008, 01:38 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
blow fishing line though with an air compressor, then pull a thicker string though with that, z bars in the past i have had to pull 1 wire at a time, you can do this by feeding 1 fishing line with 8 tied to it, pull 1 at a time
Old 07-28-2008, 01:43 PM
glide05's Avatar
glide05
glide05 is offline
As the others have mentioned - one at a time is probably your best bet. I found this to be an impossible task when I tried to do the entire bundle at once.
sold the bars out of frustration.
Old 07-28-2008, 01:51 PM
dyna rider's Avatar
dyna rider
dyna rider is offline
I don't know what you are using to pull them through (fishing line -wire- plastic-etc) but try wrapping the joint between the wiring and whatever with teflon tape and if it is still too hard, spray with silicone spray. Sometimes doing them one at a time is the fastest way.
tattoo13's Avatar
tattoo13
tattoo13 is offline
I just got done doing my Z-Bars they were a PAIN IN THE ACE!!!!!!
One at a time and be careful, I got a little skippy with pulling one that was getting stuck, and stripped the insulation off the side of the wire. Had to pull it and start over. [:@]
Old 07-28-2008, 01:56 PM
ZeroFiveFour
Ok, one at a time it is. I was&nbsp\\;trying to get the&nbsp\\;whole bundle. It&nbsp\\;was an impossible task.&nbsp\\; Do any of you recommend using wd-40 spray prior to pulling the wires? Thanks again, Tom
Old 07-28-2008, 02:06 PM
fiend138's Avatar
fiend138
fiend138 is offline
No WD if you are going to tape the wire do the guide,&nbsp\\;think of it as a game of&nbsp\\;push pull.
JRK5892's Avatar
JRK5892
JRK5892 is offline
do not use WD 40, if anything I use hair spray... i know it shounds nuts but after it works as a lube it will then tack up and help hold the wires inside from jiggling around... mostly in apes
Old 07-28-2008, 02:08 PM
fiend138's Avatar
fiend138
fiend138 is offline
Do you have a hole on the ends&nbsp\\;lower horizontal bar?&nbsp\\; If so snake it from the control to the hole, then to the center of the bar.
Quick Reply: Internally wiring z bars, Need Help, tips or advice welcome.
