fuel gauge cap
Old 03-16-2006, 11:36 PM
stc13's Avatar
stc13
stc13 is offline
Default fuel gauge cap
if I were to change out fuel caps on my street B how does one remove the fuel gauge cap with out screwing up Im guessing theres a wire connection beneath it, want to change them out and put the LED gauge on ,any thoughts?
Old 03-17-2006, 01:26 AM
05 Wd Gld's Avatar
05 Wd Gld
05 Wd Gld is offline
Default RE: fuel gauge cap
Just give it a short twist and pull on it. Slowly would be good. Do you have the new gauge yet? I know it comes with some instructions as I have done the install and it was simple. You won't have any problems. Just jump in.
Old 03-17-2006, 01:31 AM
Original Junior's Avatar
Original Junior
Original Junior is offline
Location: The birthplace of our nation- Philadelphia proud!
I was thinking of doing this but was weary of how the LED guage wired up. Does anyone have directions to look over? Thanks
Old 03-17-2006, 05:36 AM
05 Wd Gld's Avatar
05 Wd Gld
OJ, I don't have the directions anymore but, I thought I would let you know that this is the easiest or one of the easiest mods that you can make to your ride. I recall having to cut two wires and hook them back together with the new gauge. Go for it, mine looks great and I am glad I made the change.
It's all in the details.
Old 03-17-2006, 06:08 PM
Sooee's Avatar
Sooee
Sooee is offline
The fuel gauge wires are routed through a tube in the tank!
To remove, pull up on the gauge - do not twist it.
Note:- you should discard the old gasket and use a new one when you re-install the gauge (new LED one or the old one)
Old 03-17-2006, 08:48 PM
WillieC's Avatar
WillieC
WillieC is offline
The gage is just a slip fit, no threads etc. You can pull up on it and it wil come out.
The wires go thru a tube in tthe bottom of the tank and there is a connector on the end.
you must remove the wires from the connector to pull the wires thru the tube.
It is very easy to do with a small pin or something pointy. The instructions will tell you
where to depress a tab on the wiring connector to get the wire out of the connector.
Willie
Old 03-18-2006, 11:56 AM
streetbob6's Avatar
streetbob6
streetbob6 is offline
DEALER TOLD ME THE LED GAS CAP DOES NOT FIT 2006 DYNAS?
Old 03-19-2006, 01:38 PM
ridercoachbob's Avatar
ridercoachbob
ridercoachbob is offline
I have thought about doing this. How accurate is the guage? And do you have one of those with the volt meter attached as well?
Old 03-19-2006, 11:00 PM
Gadgetech's Avatar
Gadgetech
Gadgetech is offline
I have to agree, this is an extremely simple upgrade for the bike. I have an '05 so I don't know about the fitment problem, although I don't know why it would be any different. Basically you disconnect the harness which is hidden up under your tank, disconnect the clip that connects the wires to the harnes, feed it through the tube and then work in reverse with the new wires and such. It can be a pita to get the clip off the ends of the wires but they go back in easily. In terms of accuracy, it appears to be pretty accurate. They light up blue until you get to the last one (empty tank) which will shine red and then start blinking once it is really low.
Old 03-19-2006, 11:48 PM
Angry_Monkey's Avatar
Angry_Monkey
Angry_Monkey is offline
Harley has the Billet cross on their "custom" Street Bob on their site, so some of the LEDs must work on an 06 Dyna.
Quick Reply: fuel gauge cap
