200mm tire on Fatbob
#41
When I had the service done at 10k I guess the Indy I used adjusted the steering neck. It was really loose afterwards. I had the bike at a dealer a while afterwards and they noticed it right away. Tightened it up and the bike ran fine and didn't feel squirrely anymore.
#43
Ok about the performance aspect.
Your not going to loose performance going with a wider tire. Because one your going to be putting on a wider tire on a same size rim. This will cause the tire to be more round and less flat. Two, the performance will change the more straight miles you put on your bike this hold true to any round tire. So this idea of loosing performance while in turns is neutralized. If anything you gain performance due to the wider tire same size rim effect. Also you will gain performance cause the 200tire tire is. 5 inch shorter. This is also why it will wear faster.
#45
#46
I realize this is an older thread, but in hopes someone still gets notifications of actions here, I want to ask a question.
With Passenger and overnight gear, I am right at about the max suggested weight for the Dyna. Would anyone who has put a 200 on a factory rim have reservations of the 5 inch rim instead of 5.5 when riding two up?
Also the new Avons claim 15K warranty, would you suggest Avon or Metz?
Thanks!
Thanks!
#47
Received 5,374 Likes
Blue Bob (03-12-2018)
#48
Research is telling me that the Avon 200 is actually like 195mm.
And I have read multiple threads with people mounting the 200.
I was just concerned about the weight.
#49
There seems to be many people who seem to think the tire manufacturers recommendations are just that....a guide line. I had a indie argue with me that a street bob rear was 5" enough though thru his own admission it was stamped 4.5" Then went on to say a 200 was going on it for his customer
