Prevent seat scratching
when i used to use my bare bones pilion, at first i just folded a microfiber towel and placed it on the fender.
next, as a more permanent solution i took a piece of neoprene (think mousepad or wetsuit material) and cut it to fit and glued it to the bottom of the pillion, rubber side to the pillion, fabric side to the paint.
i picked up a 2up seat a week or so ago and will probably go the neoprene route again.
like was said before, just wipe down the seat and the fender well before you bolt the seat down.
the seat won't scratch your paint so much as the dust traped between the seat and your fender will.
Just an idea: http://www.zagg.com/invisibleshield/index
It's clear, it's resistant, it's flexible and it's worth a try
I don't have that problem because my fender has some factory protection, but if I mod my seat in the future I would probably use something like this. I've seen some car fenders with a similar protective film.
For throw over saddle bags, Foxcreekleather has a good solution: http://www.foxcreekleather.com/produ...g-fender-guard
Probably some can adapt it for the two up problem
Try a fender bib...HD and Mustang each have a vinyl one that some forumites have testified work great on their bikes. And of course there's plenty of custom leather guys out there making them if you want something snazzier than vinyl for when you're rocking the solo saddle.
this is probably the most important thing you can do.
I cut up an old wet suit and use a piece of it under my 2 up seat when I put it on, works great.
Had a Lepera 2 up seat on my last Harley for over 7 years, and it never left a mark. They use steel seat frames covered in carpet.
