2005 Dyna Superglide Fluid Capacities
My brother-in-law dropped off his Superglide so I could change his oil, tranny and primary fluids for him. I know the crankcase takes 3 quarts, but not sure of the tranny and primary. He left his owners manual at home, so I thought I would ask the forum for help.
Kevin
Kevin
From the 2005 Dyna Glyde shop manual:
Oil = 2.4 qts (wet)
drain plug torque = 14-21 ft lbs
Primary lubricant: 26 oz.
primary drain plug torque = 36-60 inch lbs
Primary cover torque = 84-108 inch lbs
Primary chain deflection with cold engine = 5/8" - 7/8" (do it while you are in there)
Chain tension nut torque = 21-29 foot lbs
Transmission lubricant = 20-24 oz.
Drain plug torque = 14-21 foot lbs
Filler plug torque = 25-75 inch lbs
What other questions do you have?
Oil = 2.4 qts (wet)
1999, 2005, 2007, capacities, capacity, change, dana, dyna, fluid, glide, oil, recommendations, specs, super, superglide
