How do you take apart shocks!
08-22-2008, 04:37 PM
hey yall... can someone tell me how to take apart shocks to get the coil out (spring)? i left my service manual at home and need to pull a few shocks apart for a buddy so i can powder them... can not figure it out! thanks guys!
08-22-2008, 04:42 PM
My 08 Dyna manual doesn't tell how to disassemble. Only removal. It says the shock is not serviceable and must be replaced as an assembly. [?]
08-22-2008, 05:12 PM
ahh no... i know they come apart, i just do not know how these work, i have had old ones that you just compress and then twist and they slide right apart...
08-22-2008, 05:27 PM
Agreed. They look like they come apart to me also. I was just trying to see if the manual illustrated it. Sorry.
08-22-2008, 05:59 PM
progressive sells a tool that allows you to compress the spring, and lift the clip that hold the upper and lower covers on..... you can use it for stock, 412s, 440s.... and a few others of a similar design.... it's very easy to use....you don't even have to put the shock in a vise or anything.... if you get it, it's pretty self explanatory how to use.... i had my 412s disassembled in less than 3 minutes...
JP Cycles part number 910-144
http://www.jpcycles.com/productgroup...ore=All&page=2
08-22-2008, 06:47 PM
You definitely have to exercise caution when compressing the spring. I had disassembled a set of shocks a few years back and slipped with the compression tool. HOLY crap that spring went flying...luckily away from me.
08-22-2008, 07:37 PM
tool
You have to make two tools. One to clear the top eye but seat on the retainer, the second to to go around the bottom eye both like a pipe but with part removed so you can remove and pry up the retainer ring. Put in a press and you can guess the rest. easy after the first time.
leeanders
08-26-2013 06:51 PM
jimmything
11-30-2008 09:35 PM
saracen
04-18-2007 12:17 PM
Todd Vikan
11-26-2006 06:18 PM
Mrkicks
10-20-2005 10:23 PM
apart,
compress,
davidson,
disassemble,
disassembly,
fl,
front,
glide,
harley,
motorcycle,
progressive,
rear,
shock,
shocks,
street,
taking,
works
