Dyna Lowrider Floorboards
Old 08-23-2008, 03:51 PM
virginiajoe's Avatar
virginiajoe
virginiajoe is offline
6th Gear
Default Dyna Lowrider Floorboards
I want to put a heel to toe shifter on my 2005 Lowrider but I can't find any floorboards that will fit the bike. Harley no longer sells the floorboard kits for a dyna lowrider. Anyone have any other company options or ideas? Thanks for any help.
Old 08-27-2008, 11:33 PM
girlyrider's Avatar
girlyrider
girlyrider is offline
Stage I
Default dyna floorboards
I`m also looking for floorboards for my 06 fxdli.... any info you find out would be greatly appreciated.
Thanks in advance, Rachael
Old 08-27-2008, 11:50 PM
cstolp's Avatar
cstolp
cstolp is offline
All the parts that made up the kits are still available but its gonna cost between 7 and 800 and the shifter mounts need to be modified in order to fit the 06 and newer dynas. I designed and built some interface brackets and mounted softail boards, brake master cylinder and shifter. I paid $200 for the softail take offs, about another $100 for brake lines and a t fitting. The plates I made myself. Another member bought forward control extension plates for softails and drilled those to fit the dyna forward mounts on the down tubes.
Attached Thumbnails Dyna Lowrider Floorboards-dynaboards-003a.jpg   Dyna Lowrider Floorboards-dynaboards-004a.jpg   Dyna Lowrider Floorboards-dynaboards-005a.jpg   Dyna Lowrider Floorboards-dynaboards-006a.jpg
Old 08-28-2008, 01:14 AM
MidnitEvil's Avatar
MidnitEvil
MidnitEvil is offline
Would these work? I have them on my 02 Wide Glide. Take the peg out, bolt these in.
http://www.cas4.com/Forward-Controls...oorboards.html
Go about half way down the page, or do a search. Part number is CS190505
Old 08-28-2008, 01:17 AM
MidnitEvil's Avatar
MidnitEvil
Why did this double post?
Old 08-28-2008, 03:51 PM
Ocoee Joe's Avatar
Ocoee Joe
Ocoee Joe is offline
Looks very similar to my Street Bob with modified passenger foot boards...only cost me $34 and a little time in the shop...i was being paid $32 an hour while working on them so i took my time....:>)
HDRoach
11-24-2016 09:39 AM
hog120
04-28-2014 09:38 AM
Dannell53
04-20-2011 12:38 AM
lunloon
10-20-2010 11:02 PM
cstolp
02-22-2008 11:01 AM
Quick Reply: Dyna Lowrider Floorboards
