blown signal fuse now no pump or starter?
HELP! blown signal fuse now no pump or starter?
Hello I have a 2006 Harley Dyna FXDCI for some reason my fuel pump and starter button will not work? but, This Bike has only about 3600 miles in all this is the first problem I have had with it. this all seemed to happen after blowing a fuse in the signal lights I pinched a signal wire the Left handlebar switch wile replacing my stock bars I also found after blowing the fuse I had a lose left rear signal socket in the rear signal light before fooling with this I unhooked my battery just to be safe. fixed both problems and replaced the fuse hooked the battery back up. Now I have no power to my start switch or fuel pump? Again I replaced all the fuse's and the lights all seem to work fine but still no power to the start button or fuel pump?? Any Ideas what could be the problem? Oh the battery is fully chargedcould it be the security system has me locked out? can this be cleared?.
Thanks for your time and help
vlongrider
vlongrider
Last edited by vlongrider; 08-30-2008 at 10:31 AM. Reason: wrong side rear tail light&rewrite
Received 4,282 Likes
Sorry I said right side signal light" it was the left That blow the fuse. any way I replaced all the fuses, rechecked each one with a metter only bad one was the one that was blown. checked the new ones too just to play it safe. I was told about resetting the security code to the Fobb today but the info was for an 01 fat boy with a carb. so I'm thinking it must be different? still no power to the starter or fuel pump I called the dealer all they would say was I'm locked out because of the short in the left signal and they can unlock it but I have to bring it in at a cost of about $200 Bucks" to do a fault test on the Dyna" I think I'll pass on that offer"
Don't have a dash with gauges on the fuel tankI have a gas gauge and Gas fill opening/cap. My problem all started when I pinched a wire in my left switch housing it killed my signal fuse. I disconected the battery and checked all the fuse's found the blown fuse replaced it now My 06-FXDCI will not start no fuel pump or power to the start button. I have replaced the fuse's all of them now still nothing. nothing else has been messed with other than a lose light socket in the left rear tail light I fixed that all the lights work as they should. I have been told by the dealer that my security system has me locked out and the same thing by two other dyna riders with streetbob's I know. so at this point I am really confused about the issue, I bought the bike as a repo and have no way of knowing any security code that may have been placed in the security system and I have no owners manual, I was able to use one of the streetbob owners manuals to see if I could make sure the key fobb button deal to set the security deal was set to the bike and from the info in the manual it seems to turn on and off the security system. as for the speed-O mount there are no wires pinched under the top riser clamp that the speed-o and dash lights are hooked to. any other I deas?? thanks for your reply
Virg
Virg
vlongrider
vlongrider
Tropicalwarrior
06-18-2010 06:31 PM
