2009 FXDF Extended Forward Controls
Extended forward controls
Hi,
I have a 2008 FXDF that I put the Kuryakyn extension kit on. Fairly simple job athough the brake rod was not lining up with the lever until i mounted the foot bracket on the inside of the extension plate. I'm 6'7", and it really makes a difference. Found the kit on EBay for about $140.
I'm not sure if the kit would fit the 2009. I have looked at them, and they don't appear any different to my eye.
Good Luck
wmo777
2008 FXDF
Good Luck
wmo777
2008 FXDF
Hi,
Good Luck
wmo777
2008 FXDF
Good Luck
wmo777
2008 FXDF
Hi,
Good Luck
wmo777
2008 FXDF
Good Luck
wmo777
2008 FXDF
Can you post the part number for the kit? Thanks!
Do you have stock tommy gun exhaust?
There is this note of Part# 9049 in Kuryakyn website:
"Will not fit '08 Dyna Fat Bob if equipped with stock exhaust."
But if you have install it with stock pipe, then I try too
Trampas
Trampas
