Swapping Stock Turn Signals for LED Mini-Bullets
Old 11-02-2008, 10:54 PM
rockon's Avatar
rockon
rockon is offline
Default Swapping Stock Turn Signals for LED Mini-Bullets
Load equalizer absolutely required?
Old 11-02-2008, 10:58 PM
SikRyd's Avatar
SikRyd
SikRyd is offline
Yes, unless you like fast flashing leds.
The reason being is that the halogen have a higher resistance. The leds don't, so all the load equalizer is, is a resistor to help so the flasher senses resistance and doesn't turn on/off fast.
Old 11-03-2008, 12:03 AM
rockon's Avatar
rockon
rockon is offline
Thanks for the info. Anybody used this particular brand before? They look just like Kury Mini-Bullets, but I'm wondering why they're so inexpensive...
http://www.bkrider.com/cross4/produc...&sku=C01050106
Old 11-03-2008, 01:23 PM
Mascman's Avatar
Mascman
Mascman is offline
My guess is that since they say "single element" and there's no mention of LEDs is that it's just a standard bulb.
Usually, if it's LED they're not shy about telling you OR charging you!
Old 11-03-2008, 01:41 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
they are not LED... they have a bulb in them... in all honesty they are not as small as you think either, just a bit smaller than your stock set up...if you do go with LED later you can get resisters at radio shack and wire them in... i have led turn sigs all around on mine... i like the hyper flash, i had the resister on there then took it off cause i think it is cool... they start slow then go fast! i like that
here they are on you tube
http://www.youtube.com/watch?v=gEa1qPAVEkw
Old 11-03-2008, 05:42 PM
rockon's Avatar
rockon
rockon is offline
Yeah, I realized that right before I checked back in with this thread.......noticed that lack of "LED" mentioned anywhere in the description.
Are LED's really all that, or would incandescents be a better bet?
Old 11-03-2008, 05:47 PM
stevengb's Avatar
stevengb
stevengb is offline
do they still self cancel without the load equalizer? Nice lights below the headlamp too. Very cool.
Old 11-03-2008, 07:30 PM
rockon's Avatar
rockon
rockon is offline
By element, does that mean the single wire? Is it better if it's got 2 or 3 separate wires?
Sorry...not much of a lighting wiz.
Old 11-03-2008, 09:48 PM
Livi1215's Avatar
Livi1215
Livi1215 is offline
Good question. I have some small bullet ones and have not put them on because they are single wire and I'm not sure what they will do. Does any one know?
Old 11-03-2008, 10:10 PM
r00k's Avatar
r00k
r00k is offline
I don't think load will have any effect on canceling as this is controlled by a sensor under the seat.
I believe Element should be referring to the filament in the actual bulb
Quick Reply: Swapping Stock Turn Signals for LED Mini-Bullets
