My FLDCI project
My FLDCI project...new pics 11-16-08
I know I'm not the first to do this (SURFOR Chop has made this conversion on his bike)but here it is anyway. I ran into a few new challenges with the 2006 that made this a little interesting. Here is the before shot, not a great one but it is what I have.
As you will see in Priest's post and on Ken and Judy's site the stop on the neck needs to be ground down or the trees will not fit.
The next thing you have to attack are the steering stops on the lower tree. You have to remove a fair amount of material to get it to turn. I used a scribe to mark where the headlight bolt was a full lock with the original forks and then ground the new trees until they matched.
I know a lot of you don't use the lock feature but it is a habit for me and I wanted to retain it. The Fat Boy locks inside the neck so I hade to make a bracket to work with the bike. It was pure dumb luck hat this worked out. I set this up where I thought it would line up and instead of tacking it I welded it solid, thankfully it worked.
The original lower tree has a raised boss that the Fat Boy tree did not have. I don't know if this was an issue on the earlier bike but it was here. I used a hardened washer that was as thick as the boss was tall. With out it the tree bottomed out on the neck before the bearing found the race.
Had to start a new section since you can only put five pictures per post. The washer on the tree moved them apart enough that I had to oblong the mounting holes for the nacelle to get it to fit. Easy enough but the next issue with the nacelle was the wiring harness's coming out of the frame. It would pinch them at full lock so I had more mods to do. Nothing worse than cutting the snot out of new expensive parts!
Once all that monkey business was sorted out, here is where it sits.
I have a Street Bob tank for it and a Road King fender that I need to make fit but at least I'm real close to being able to ride it again. Next thing I have to do is decide what to do for paint.
Took some more pics today. Here is one from the side.
I decided not to widen the Road King fender. I bought a Street Bob fender off of ebay and I am grafting the bottom rear of the RK fender to it. It will be much easier with my skill set.
I stll have no idea what I want to do for paint, I am leaning towards a dark green but that could change by morning.
looks great. i'm going to use a rear fender frome an 09' roadking classic, its the same width as fatbob rear . i will have to patch some mounting holes. i'm still don't know what i want to do as far as old fxdp floorboards or new softail style . both need minor mod, but i want the easiest route. anyway, great job. Brian
