Rear Wheel Upgrade
look at the clearance between the belt and tire - and that probably answers some of your question.
if you keep the stock wheel - you can put a 160 on there (Metzeler).
If you want a wider tire than160 - you will need a wider wheel, and then must first address the belt clearance, space the pulley off the wheel, then get a narrower belt. that will be quickly followed by the tire/fender clearance. so as mentioned - it all depends on how much work you are willing to put in
