103" Twin Cam "SHO" dyno numbers
Old 12-08-2008, 02:45 AM
Centerline's Avatar
Centerline
Centerline is offline
Default 103" Twin Cam "SHO" dyno numbers
Last week the requisite 1,000 miles was reached for my dealer to perform a dyno tune of the 103" engine that my new Fat Bob was modded to when I bought the bike. For sure it is no inline 4 litre bike, or a match for my 145HP Ducati Monser. But the numbers are pretty fine for an antique, air-cooled V-Twin engine.
Hope the columns below stay lined up when posted.
My build is all Screamin' Eagle parts, (exc pipes). CNC ported heads, 50mm throttle bodies w/ hi-flo injectors, 10.5 HTCC pistons, 260 Cams, SE tappets, SE ECU, Heavy breather, D&D Fat Cat 2-1 pipe.
Numbers are at the rear wheel.
Stock 96" Twin Cam......................My 103" SHO
RPM....Torque....RWHP............RPM...Torque..... RWHP
2500...75 ft-lb....38 HP...........2500....80 ft-lb....35 HP
3000...77 ft-lb....45 HP...........3000....86 ft-lb....50 HP
3500...78 ft-lb....52 HP...........3500....96 ft-lb....66 HP
4000...75 ft-lb....56 HP...........4000....100 ft-lb...78 HP An extra 22 ft-lbs over max stock !
4500...70 ft-lb....60 HP...........4500....100 ft-lb...90 HP
5000...65 ft-lb....63 HP...........5000....98 ft-lb.....95 HP
5500...62 ft-lb....63 HP...........5500....98 ft-lb.....103 HP
6000...X.............X................6000....90 ft-lb.....105 HP That's an extra 42 HP over stock !!
6500...X.............X................6500....85 ft-lb.....103 HP
Pleased with the numbers. The bike pulls really hard and just keeps pulling harder as the revs rise. The engine is still loosening up and I expect it will yield a few more ponies.
Old 12-08-2008, 03:35 AM
ZChan's Avatar
ZChan
ZChan is offline
Those look like good numbers. Thanks for posting them. I probably would rarely use the higher rpm's though. More than enough power in the middle where I ride.
Old 12-08-2008, 03:49 AM
Centerline's Avatar
Centerline
Know what you mean, but when I twist the wick, especially below 80 mph, the RPM winds out of the mid range pronto, not to mention that the upper rpm range on the big V twin seems like low to mid range for a sport bike guy like me.
Old 12-08-2008, 05:10 AM
sniper77's Avatar
sniper77
sniper77 is offline
Those are great #s but I thought a 103" build was the step up for an 88" engine and a 110" was the step up for a 96"??
Old 12-08-2008, 06:06 AM
Dawg Rider's Avatar
Dawg Rider
Dawg Rider is offline
96 to 103 = 88 to 95.
Old 12-08-2008, 06:16 AM
formike56's Avatar
formike56
formike56 is offline
those are good numbers. I had the same build when I purchased my WG. Except I had the 255 cams. @ 5500 mine was gettin 98Lbs torque 96 hp to the wheel. It will get better once it loosens up a little.
Old 12-08-2008, 07:26 AM
domenicp7's Avatar
domenicp7
domenicp7 is offline
Formike you are getting good numbers with that build also. I think I need to really look at the Fat Cat 2 into 1
Old 12-08-2008, 07:30 AM
sniper77's Avatar
sniper77
sniper77 is offline
Thanks, brain fart this mornin'!
Old 12-08-2008, 09:28 AM
dyna mo's Avatar
dyna mo
dyna mo is offline
nice! intersting that the hp at 2500rpm is a bit lower but the torque is increased over stock
btw, which monster cranks out 145hp?
Old 12-08-2008, 11:20 AM
murphdog's Avatar
murphdog
murphdog is offline
The horsepower numbers at 2500 rpm appear to be reversed.
75*2500/5252=35.7hp
80*2500/5252=38.08hp
Quick Reply: 103" Twin Cam "SHO" dyno numbers
