39mm fork clamps on a 41mm fork
im about to buy a windshield from an 05 superglide that has 39 mm forks, my 07 streetbob has 41 mm forks, it has the docking hardware that stays on teh bike and the shield clamps to the hardware, is there anyway to make this work by welding or anything, or would i have to buy new hardware???
just buy new hardware... it will not fit and either crack the clamp trying to make it work (this will be mostlikely what will happen) or it will not seat flush and jiggle as you ride, this will mar your forks, and possibly have it shake loose... imagine your windshield starting to fall off while you are doing 75 down the highway!!!! not worth it brother, pick up a replacement clamp for your ride... then all you have to do is figure out how to make it line up to the mounting brackets on the shield and your docking hardware... your forks are going to be WIDER on the 49mm than they are on the 39mm so the shield will not line up either...
Mr Bentwrench
02-17-2015 01:42 PM
