What are the Fat Bob Horsepower numbers?
I had my fxdc dynoed before and after the stage 1,stock was 64hp & 84tq at the rear wheel. Stage 1=SE heavy breather,V&H big radius 2-2 w/bct baffles,SERT= 76hp & 93tq. But Rounder's #'s were a bit higher. Dyna105SE I think your stock 110" was 87-89hp & 94tq. When I was having my motor done I was talking to the service manager about stock #'s on the SE models. He showed me a dyno sheet from a '08 dyna that was recently done and was surprised at the #'s. Thought they would of been a little higher.
My build is all Screamin' Eagle parts, (exc pipes). CNC ported heads, 50mm throttle bodies w/ hi-flo injectors, 10.5 HTCC pistons, 260 Cams, SE tappets, SE ECU, Heavy breather, D&D Fat Cat 2-1 pipe.
Numbers are at the rear wheel.
Stock 96" Twin Cam......................My 103" SHO
RPM....Torque....RWHP............RPM...Torque..... RWHP
2500...75 ft-lb....38 HP...........2500....80 ft-lb....35 HP
3000...77 ft-lb....45 HP...........3000....86 ft-lb....50 HP
3500...78 ft-lb....52 HP...........3500....96 ft-lb....66 HP
4000...75 ft-lb....56 HP...........4000....100 ft-lb...78 HP An extra 22 ft-lbs over max stock !
4500...70 ft-lb....60 HP...........4500....100 ft-lb...90 HP
5000...65 ft-lb....63 HP...........5000....98 ft-lb.....95 HP
5500...62 ft-lb....63 HP...........5500....98 ft-lb.....103 HP
6000...X.............X................6000....90 ft-lb.....105 HP That's an extra 42 HP over stock !!
6500...X.............X................6500....85 ft-lb.....103 HP
Chris in CT
