handle bar wiring connector question.
Old 12-22-2008, 07:34 PM
Goddahavit's Avatar
Goddahavit
Goddahavit is offline
Default handle bar wiring connector question.
I have been through the my ape install thread , and i have gotten to my wiring, (including pulling the connector off the switch(i think)(opps)
my problem is my connector isnt like the thread.
Anyone have nay idea how to get this connector apart?
I am guessing everyone just cuts and solders at this point it would probably take less time...
thanks, Eric
Attached Thumbnails handle bar wiring connector question.-img_4491.jpg   handle bar wiring connector question.-img_4492.jpg
Old 12-22-2008, 07:36 PM
jarhead45's Avatar
jarhead45
jarhead45 is offline
I think those wires will pop out of that connector with the tool
Old 12-22-2008, 07:38 PM
Goddahavit's Avatar
Goddahavit
the tool?
Old 12-22-2008, 07:40 PM
blackmopar's Avatar
blackmopar
blackmopar is offline
need a pick set - a straight and bent work best for me
and beforehand LABEL LABEL LABEL - its tedious and time consuming (hence why labor for ape installs is so much)
ill post a god thread on this if I find it
Old 12-22-2008, 07:42 PM
chad peterson's Avatar
chad peterson
chad peterson is offline
They pop out very easily, I use one of them super tiny standard screw drivers to flip up the tiny tab inside. Look real close, you'll see them!
Old 12-22-2008, 07:45 PM
blackmopar's Avatar
blackmopar
found it
this article got me through my first rewire
patience, and did I say LABEL??!??
https://www.hdforums.com/forum/dyna-...e-install.html
Old 12-22-2008, 07:48 PM
northern lights wg's Avatar
northern lights wg
northern lights wg is offline
I just did mine this weekend. Take a needle nose plier and grab the two d holes in the center and pull up about 1/2 inch, then take a large paper clip and stick in the holes behind each pin and push in all the way down and pull the wire out gently.
Old 12-22-2008, 08:03 PM
chad peterson
Ya that's better, I suck at explaining things! I'm better at doing as I go & do it again no prob, but don't ask me how I did it. LOL, probably why I'm a heavy equip. operator!
Old 12-22-2008, 08:12 PM
Goddahavit's Avatar
Goddahavit
thanks, that was it exactly, and my pic didn't fit so it just locked it again, but a small paperclip works great... thanks.
Old 12-22-2008, 08:17 PM
northern lights wg
Glad it helped. What bars are you switching to.
Quick Reply: handle bar wiring connector question.
