0-60 time?
Good point. Factory stock performance cars are wildly faster than the stuff that ruled the streets in the 60s and early 70s. A base, coupe '09 Corvette with automatic rips 4 second flat 0-60 and 12 flat 1/4s on stock run flats! That is simply amazing for an EPA compliant, showroom stock vehicle. The old big blocks are a joke when compared to these new high tech machines.
I don't know about that. I owned a stock '70 Olds 442 back in the early 90's and raced a Mustang GT on the highway. I could tell it had a little work done to it. To say that all he saw was my taillights is an understatement. Nothing better than pure brute force horsepower.
The early 90s Mustangs were pretty weak. The current gen., '05 up Mustang GTs will run mid 13s bone stock. The average muscle car from the 60s ran high 14s to high 15s. That was damn fast back then. Big block Mopars, Vettes etc. could get you down close to 14 second quarters in factory config. Obviously anything can or could have been modified to perform better.
A current GT500 or GT500KR Mustang will run low 12s, mid 11s respectively, both on stock tires and would flatly destroy from anything Detroit had to offer back in the day. Crazy but true.
Don't forget that the pre '72 cars used a completely different rating system(BHP) for HP than the current cars use(SAE). The old stuff would post HP #s about 25% lower under the current SAE standards. The old motors were also the victim of significantly higher parasitic driveline losses. The performance cars in todays showrooms have acceleration, cornering, and braking capabilities that were unimagineable off the assembly line 40 years ago.
Wicked Cricket
07-20-2011 03:06 PM
