Stupid Gas Gauge!!!
Stupid Gas Gauge!!!
My DWG has a 5.2 gallon tank (according to the owners manual). After using about 2 1/2 gallons, the damn needle pegs on Empty.
Will a 2 or 3" tank lift help with a more accurate reading or should I look at an aftermarket gas gauge? I realize some just use their odometer but I would like a little more accuracy. Maybe it's just me but using a 1/2 tank of fuel and the gauge reading E is frustrating. Haven't run out of gas but maybe I should put a gallon of gas in one of my saddle bags and run out on purpose to see exactly what the bike can do.
Suggestions?
Suggestions?
Tank lift will make it less accurate. The arm with the float on it needs to be bent so that it sits at the proper level. Mine was the same until I swapped tanks at which time the arm was bent and now it is close to accurate. Just go by the odometer. That is what I do as well. NEver trust a motorcycle gas guage. IF you have ever run out of gas on an mc you'll know hat a pain it is to walk it down the freeway to the nearest gas station.
Have heard of this happening to a few but actually a tank lift would probably make it worse the more level a tank is the more accurate it should be ... Lived for a lot of years on Bikes with no Gauge at all.. My Sportster is real simple 100 miles and best start looking actually start looking at 80 but know am safe til 100 Miles .. Would assume your level indicator is defective.. Love the Gauge on my FLHT and so far is pretty accurate but it's new time will tell if it stays that way..
My fuel gage seems to be fairly accurate, but I agree with the others, you should never rely on the gauge and instead go by the trip odometer reading to know when it's time to start looking for a gas station.
I usually start looking for a gas station when the trip odometer is at 115 to get refueled...I don't like to wait for the low fuel light to come on...the tank usually takes about 3.3 gals to fill, I reset the trip odometer and I'm good to go.
Suggestions?
Suggestions?
Really appreciate your thoughts and suggestions my Harley Bros!
Was considering a tank lift and wasn't sure if I would get an extra benefit with my (and other's) fuel gauge problem.
Probably still going to due a 2" tank lift but guess from the recommendations is that I do the odometer reading thing until China invents an accurate gauge (that's sad).
