Turn signal question
1 Post
I just put a pair of led turn signals on my bike, and installed the load equalizer and tested them and everything worked fine then I had a wire touch and blue a fuse so I replace the fuse and now every thing works except the left signal. I also have module that turns the turn signals into brake lights. Any ideas on what might of happened Thanks I forgot to say that my bike is a 03 lowrider
so just the left side doesn't work? and does it do anything at all like signal but no brake. brake but no signal etc. Sounds like possibly something fried in the brake module you added or you have a wire that is cut or burnt open. Not sure how the brake module does its thing but everything hooks to that module and it could be the problem remove it and see if it works then.
