Inner Primary Cover
Inner Primary Cover
I am planning to replace my inner primary cover with a chrome inner primary cover. Are there any special tools required?
I do have the shop repair manual and basic tools. I was wondering if the job requires any special tools such as bearing presses, etc.
This would be on a 2008 Dyna Lowrider.
Thanks!
Thanks!
You will need a primary lock tool. Several have easily made their own versions of this tool. The tool is specific for the 06 and later Dyna (07 and later other models) twin cams. The tool for earlier models can do damage. I also believe you need a 30mm sockeet. There is a complete write-up by a forum member named silverbullet2005 in the do-it-yourself tech help section.
gonna also need a 1/2" breaker bar for the compensator nut(possiby a impact wrench depending on how tight it is and your personal elbow grease)... You can get the bearings and seals pressed in at the stealer then take home and install... If the tools are gonna be close to install price you may just want to pay someone to do it instead. Also a good torque wrench if you don't have one... the tools add up.
Thanks!
Thanks!
Have a look at your stator while you're in there
(your 08 is probably the good one- welded)
Have a good look at the inner primary bearing and race,
you're probably good there as well.
the locking tool is simply a 7" long x 1" wide x 1/4" flat stock.
Follow the manual, you'll be fine.
mud.........
