Here are the results from the dyno tune. I know it is upside down.... The pdf that is. Numbers are a little less than what I thought I would get.. But they are better than stock. Tried to down load pdf. Wouldn't file to big...... Damn computers. How do you downsize a PDF file????? any help would be appreciated.
It runs a lot stronger all the way thru the power band. It was never stock since it was new. Before I picked it up new had the Stage II 103" installed. Granted it is a lot more torque than before..... hmmmmmm what can I do now?????
Did the dyno & breakin service at 600 miles. Maybe when it loosens up a little will do it again. I was thinking with the head work & cams I would have been around 110+-hp...
Originally Posted by sniper77
With headwork and highlift cams I'm surprized the HP isn't quite a bit higher. How many miles did you have on the new build before the dyno run?
That would be my expectations, what tuner are you using?
Using a PCIII tuner. As for valve size... I think the valves were stock... Don't really know. I will have to ask the people that did the head work. I know they change the sping's and changed the grind on the seats....
