Alternator Destroyed
Screws came out of the rotor this weekend and completely destroyed the alternator, what a mess, copper windings everywhere. Apperantly this happens so often there's a kit. Local dealer wants $335, did a search and Zanottis wants $200. Same part number 40356-06B. Question: how is Zanottis on shipping? Neither my local stealer or Zanottis have this in stock. Any other recommendations on where to get the parts? Thanks!
The 06s and some early 07s (I believe) had two piece units. A bunch of them have failed as the bolts back out. Newer models use a welded unit.
Is there any early warnings of this befor it self destructs? Should i just go a head and pull the primary apart now befor it happens? I have 22k on it now and havnt had any charging issues yet. its a 2006 FXDI.
I am trying to attach a couple of pics we will see how this comes out. The Stator is one piece but the Rotor is two pieces held together by 8 allen head screws. The heads of the screws are facing the stator when assembled. I find it hard to believe that this thing just exploded all at once, I think it had to be progressive and by the looks of it it probably was. When it happened I was pulling into a parking lot when all of a sudden I heard a slight grinding noise coming from the forward primary followed immediatly by the check eng light and batt light. I immediatly shut it down and coasted to a stop. I made a phone call got home to my truck and brought my trailer back then pushed it on and took it home. In hind sight for the past 5000 miles or so I have been hearing a very slight ringing noise from the front of the motor. This sound was not evident at idle and you really had to listen for it at speed. I just thought it might be in the valve train somewhere but it may have been a couple of the screws that were starting to back out. Bike has about 25000 miles on it now and knowing what I know now I would take it apart and check the screws before this happens. I had no charging issues before hand. It does not appear any type of lock tight was used from the factory but I will at least use the red locktight when I reassemble. I am considering tack welds with the mig as long as it will not damage the magnets in the rotor.
your right about that,dealers here say they never heard of crank failures,i"be thru 2. my 06 dyna stator came apart,dealer relaced it with a updated welded one,all are welded mid 07 up. first crank twisted less than 100 miles after the stator came apart, dealer warranted the stator but not the crank, dealer and moco said once i put in cams engine warranty was voided.
