Fatcat Height/Position.
Hi,i'm trying to decide which 2-1 System to fit to my 07FXD,my question is,are there 2 mounting positions for the muffler section,on a Fatcat.i've seen different pics of Fatcats on Dynas where the Muffler section seems to be mounted at different height/angles,I also think i've seen the same thing with Thunderheaders.
Brit.
Brit.
I believe for the 07 and later bikes there is more of an upswept design and for the 06 and earlier it is more flat. Or maybe the 05 and earlier. You can see them on the website, they have pictures of both. www.danddexhaust.com
J.B.
Just looked. 06 and up have the upswept. Look under the catalog link, you'll noticed 2 Fat Cat under Dyna.
J.B.
I should be able to tell you soon when mine get here for my '07 FXDC . They also have the Boarzilla line that are much more upswept than the Fat Cat line. I think the previous comments are correct about the '06 and later being more upswept. Take a look at rounder's ('05 FXDC) and WS6 Formula's ('06 Lowrider) WS6's has a more upswept look to it.
Thanks for the replies,So that explains the different angles,except maybe the pics that WS posted shows the 06 & Later Dyna,from the website & Ws's 06 Lowrider(beautifull bike) & the angle looks different on those pics,on the D & D pic the swingarm is almost hidden,but on the 06 Lowrider,the swingarm is much more visible & the muffler follows the line of the Swingarm,rather than sweeping up,if you see what I mean.
Brit.
Brit.
Brit.
Brit.
Perhaps...
Bart
But the other possibility is that WS6 may have used a set of pipes for a 2005 model Dyna. Can't tell whether there are any bung holes for the O2 sensors or not by the angle of the photos. Could be that he installed the 05 pipes and eliminated the O2 sensors hence the more level look of the pipes going back across the swingarm? Only WS6 knows for sure!
Bart
Bart
my 05 with 12" fatbob shocks:
Rounder...
Bart
