CV Carb : Rejett Replace or adjust Idle Screw
Received 4,281 Likes
If you opened up the air intake,i.e. S/E air filter or it's equivalent , then yes you should really readjust the air mix. What I've done is richen the mix about 2 1/2 turns then once the bike is good and warmed up lean it out just a tad until you get the carb farts. When that happens go rich just a tad until the farts stop. 2 1/2 turns will put you in the ball park.
adjust, adjustment, carb, carberator, cv, davidson, dyna, fart, glide, harley, idle, location, mixture, performance, screw
