removal of license plate bracket
Old 03-03-2009, 10:33 PM
wiegs's Avatar
wiegs
wiegs is offline
Default removal of license plate bracket
Hi guys, I don't have a service manual and I am wondering if I can get to the wiring and license plate bracket without removing the rear wheel?
Old 03-03-2009, 10:36 PM
ackman1968's Avatar
ackman1968
ackman1968 is offline
You should be able to, it's just 3- 1/4" nuts (7/16 wrench).
Old 03-03-2009, 10:38 PM
Grind's Avatar
Grind
Grind is offline
Easy, unless you have Popeye arms.
Old 03-03-2009, 10:42 PM
JaronB's Avatar
JaronB
JaronB is offline
It's no problem getting in there! You may need a little talent balancing things at the tips of your fingers especially putting the nuts back on, but that the toughest of it all.
Old 03-04-2009, 05:47 AM
bigVtwin88's Avatar
bigVtwin88
bigVtwin88 is offline
You should be fine. I removed my plate bracket to do the laydown mod with the bike sitting on the kickstand and I have 11" shocks. It was a little annoying but still not worth getting the 79 sporty I'm rebuilding off the bike jack. One word of advice, though, would be to get some latex gloves and wear long sleeves. You'll be amazed how dirty it is up in there. I'm not afraid of a little dirt, it would just save you the trouble of having to clean a bunch of grimy fingerprints off the fender when ur done.
Old 03-04-2009, 06:00 AM
jnogreen's Avatar
jnogreen
jnogreen is offline
Get some neddle nose vise grips.... My arms were to big to get a wrench in there too...
Old 03-04-2009, 06:09 AM
HarleypsychRN's Avatar
HarleypsychRN
HarleypsychRN is offline
If you have big arms and hands plan on being down there for awhile. Can be frustrating but you'll eventually get it.
Old 03-04-2009, 09:51 AM
lowrider966's Avatar
lowrider966
lowrider966 is offline
It can be done. If you have a problem getting under there fab up a wire coat hanger with some duct tape or gorilla tape wrapped sticky side out around it. Stick the nut or bolt on there and go fishn'. I had to do this to get my seat mount nut/clip combo back on after changing seats. Just watch not to scrath the paint.
Old 03-04-2009, 12:02 PM
r00k's Avatar
r00k
r00k is offline
If you have a jack make life easier and jack it up prop up the wheel and remove 2 of the shock bolts. wheel will move down to give you much more clearance and you wont have to worry about alignment or belt tightness once you are done.
Old 03-04-2009, 12:04 PM
octane's Avatar
octane
octane is offline
+1 on the jack. It will make your life much easier if you have big arms and lowered suspension. Really easy
caberto
09-19-2017 01:49 AM
IrIeSpringer420
04-01-2015 06:43 PM
Tom84FXST
03-02-2012 07:08 PM
Dyflam
12-04-2009 01:55 PM
shoefits
02-22-2007 05:07 PM
Quick Reply: removal of license plate bracket
