Dyna MC Batteries
Been doing some research for a new battery and thought I would post.
The HD OE battery for my 06 Dyna is made by East Penn-Deka
HD OE battery at the dealer (Deka) 270CCA $100-120.00
East Penn Deka EX20LBS 270CCA at a deka dealer $79-88
Note: ALL are AGM sealed batteries.
If you go to the east penn-deka website they have a dealer locator.
http://www.eastpenn-deka.com/
check all of those carefully before you buy for 006 and newer Dynas.
006 up has a very tight fitting battery box.
I know in my experience the InterState/Yuasa
would not go in without forcing it,
and would not come out short of a prybar.
I sent it back and went with the HD.
I did a lot of research as well,
looking for a high performance unit to crank my hi compression motor.
and I just could not find any hiPower batts to fit into the compartment.
The HD cranks just fine though. no issues.
Also, each manufacturer rates cranking using different formulas,
and they can be very misleading.
mud
mud
I checked with both:
East Penn Deka: 6 7/8 L x 3 7/16 W x 6 1/8 tall
Yuasa: 6 7/8 L x 3 7/16W x 6 1/8 tall.
I am going to get the Yuasa Interstate but will take my core out and take my tape measure with me. The Deka is the HD OEM battery for sure. But I'll measure mine first because. But like you said it is tight in there. I put a cloth ribbon strap taped to the back of the battery to be able to pull it out easy. Otherwise the stock battery in my bike is a bitch to get out.
Received 4,309 Likes
How long can expect my stock battery to last??? how long are people going on the stocker???
My '06 Dyna just had it's birthday and is now 3 years old and the stock battery is still working fine. I ride year round and have 18,500 miles. It always cranks fine but i learned when i got it that you dont want to sit there with the key on and it not running for more then 30-60 seconds or it will crank slow cause the headlight drains it down.
