Dyna MC Batteries
Update
Well I took out my battery and went and compared it to the Yuasa and Deka batteries and Mudpuddle is correct. While both batteries will fit in the box the terminals on the Yuasa brands are different from the Deka which is identical to the HD stock battery and made at the same East Penn factory. So I bought the Deka. Got it home and it slipped right in and the cables bolted right up no problem.
So my recommendation is the Deka ETX20L for the 06> Dyna $79.00 as it is the same as the HD one. For all other years I would hit the Deka website and find a local dealer. They will have a direct fit for your bike since they make all the batteries for HD.
Help! I've had so many battery issues since my stock battery died. I'm really frustrated.
The battery I got from Walmart wouldn't fit, once I actually got it in place, the chrome battery cover won't fit back on. I took it back for a smaller one, $85. That battery lasted less than 6 months but it only came with a 90 day warranty so tough luck. Buy another. (I don't have the brand name, I'm at work and can't look at the recpt.)
I then got a battery from Autozone because they said it had the most "cranking power", $130. This battery barely fits as well, I actually had to zip tie the chrome batter cover to the bike to keep it from vibrating off. Few things make you look as stupid as parts falling off your motorcycle as you ride. But this battery has lasted about 6 months and then this morning it wouldnt start.
I ride almost daily, no issues until yesterday, it started but it not by much. I rode it home and put it on the battery tender. This morning, not enough power to crank it up.
Should I go back to Harley brand? Is it all about Cranking power? Is this a battery issue or could there be something wrong that is draining the battery? Any insight would be helpful, thanks.
mine only lasted two years and i was using a battery tender. got this battery a few months ago and no problems, plus 500cca
http://www.wholesalebatteriesdirect....l-battery.html
Put a Walmart (Yuasa?) AGM sealed battery in my Softail this spring. Can't tell any difference in it and the Harley one when it was new. Be interesting if it last as long (6 years) but it was about 2/3 less. Guess it was worth it. Did have to pour the acid in and cap the openings. On a difficulty scale of 1-10, probably a 8 for most since the caps where tight and you had to match all those funnels to the openings. Also had to watch it all night as it charged up. That was a lot of effort to save $130.
