Front fork oil?
03-08-2009, 07:23 AM
Front fork oil?
The manual says use only HD oil.
What fork oil\weight do you use?
Naz
03-08-2009, 08:21 AM
03-08-2009, 08:50 AM
Quote:
Originally Posted by
madden23
15W works for me.
Whats the difference in weights.... The thicker the harder the ride?
I wanna tighten it up a bit so should I go with a heavier oil like 30W?
Thanks, Naz
03-08-2009, 09:27 AM
I have progressive standard length springs and 20W oil in mine.
Rides a bit stiff, I was thinking of changing out the oil for a lighter weight.
03-08-2009, 10:22 AM
I used the SE fork oil. Stiffened up the front a bit. Not sure what weight it is though, but it did exactly what your wanting it to do.
03-08-2009, 10:33 AM
stock is 10W. If you want to stiffen it up a bit I would go with HD SE oil or a 15w. I run BelRay 15z in mine with progressive lowering springs. 20w will probably be pretty harsh.
03-08-2009, 11:19 AM
Naz_Man
Naz
The manual would also tell you to only use Harley Davidson gasoline if Harley Davidson sold gas. I'm using Amsoil oil in everything.
Shock Therapy Suspension Fluid #10 Medium (STM)
Formulated for fade-free dampening and smooth rebounds in high-performance applications.
https://www.amsoil.com/storefront/stm.aspx
03-08-2009, 11:34 AM
Amsoil Shock Therapy is working fine for me.
Location: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Pouring in HD SE today, based of positive recommendations here. First, finish installing my new chrome lowers.
03-08-2009, 11:40 AM
Heavier weight oil will increase rebound, so if your front ends feels "bouncy" (poor rebound) increase wt of oil.
65Tiger
07-15-2018 10:15 AM
FireFighter200
05-01-2017 11:59 AM
kjkustoms
06-25-2012 09:21 AM
K9BO
04-08-2012 09:01 PM
zoood
11-25-2008 05:11 AM
2006 ,
davidson ,
dwg ,
dyna ,
fork ,
forks ,
front ,
harley ,
level ,
low ,
oil ,
rider ,
sae ,
wt
