Neutral & key light stays on??
Neutral light and security red key light stays on while riding at every gear.
If i put bike to side arm at neutral gear with or without clutch, it will shut down the engine..
Is it problem with neutral switch or what???
Diagnostic says : B1155 Neutral Switch Input Short to Battery
How can i test switch? with jumpwire or what?
2008 Street Bob
Thank you for help!
2008 Street Bob
Thank you for help!
2008 Street Bob
Thank you for help!
2008 Street Bob
Thank you for help!
The short is either in the switch or across the two leads running to the ECU, meaning that the switch is acting like its always active and there for in neutral.
This is why they always tell to not trust the light, if the switch shorts the Neutral light comes on...
EDIT: run the continuity test when the bike is shut off. Remember, in gear, bike off; if there is continuity then it's a bad switch.
Rik E Ric (DJ RUKUS)
10-21-2022 05:15 AM
