The factory overall rake on the Street Bob is 29 degrees. You will need to find out what your trail is now and what a raked tree will do to that measurement. You need a minimum of 2" trail, when you get closer to 4" it will like to go straight, but turn like a cement truck, less then 2" and you will get a bad wobble at higher speeds.
The total degrees may be the same, but the neck angle of the wide glide has the right geometry to give you correct trail, where adding a raked neck to a different neck angel, the geometry is not the same and you may not have correct trail.
