tire lifespan
Depends mostly on your riding style. I got 12k out of my last rear and just replaced the front at over 17k.
If you ride 2 up, more wear...if you accelerate hard, more wear....tire brand and style....makes a difference as well. Dunlops wear a little longer as they are a harder rubber, Metzler wears a little quicker as it is softer and stickier, etc...
You will get varying answers on tire life.
On my 07, I got 13k+ out of the rear with doing only ONE good burnout at MB bike week '08. The front went just over 15k before changing. I do ride 80/20 solo/2up and I don't usually carry a lot of stuff wth me other than my jacket. This is the first set of tires I've gone through. Softer tires will wear quicker but handle better. I did have my shocks on #4 but recently tried #3 to soften the ride for my g/f. It's not bad.
You have the shocks set at the stiffest setting? Ride 2-up a lot? Carry a lot of stuff?
Must be this batch of tires there pugs..... I also just did my 5K, and the rear tire is almost down to the wear bars. These are the stock Dunlops..... crap, if they are supposed to wear longer, I'll be going through at least two back tires a year if change to a 'good' tire.
I ride a softail, but put 42 and 44 front and rear in my tires. I beleive the book states a far lower pressure, of course that is on the stock tires. I run brands other than stock and go by what it says on the sidewall. If I had a sporty with stock tires I'd run at least 36 front and 40 rear. Some might say I am crazy, but I like to achieve a balance between handling and tire life span. Ask around, there are many different opinions on tire pressure. Check your pressure 1 time a week too.
