DYNA suspension adjustment
RE: DYNA suspension adjustment
Depends on how many pounds the sig. other is adding (and how much you contribute ) I believe the stock setting is three. I usually set mine to 4 for both single and two-up riding. I tend to like a little bit stiffer ride. I'm 210 lb and the wife adds another 125.
To change the setting, you could try and muscle it...or you could go to a harley dealer and pick up the shock wrench (forget what it's called...spanner???) It'll cost you about 10 bucks.
Todd
Todd
The shocks have a series of lobes on the inside of the spring. As you rotate the bottom of the shock a pin rides up the lobe till it drops in to a notch at the top of that lobe. Each lobe compresses the spring a little more. There are 5 positions on my 06 Dyna. After the last lobe it drops back to the first one.
Get a Shock wrench. You will save yourself some pain and scratched chrome.
