oil drain plug
Old 07-11-2009, 03:33 PM
jakeots's Avatar
jakeots
jakeots is offline
4th Gear
Default oil drain plug
can some one please tell me where the oil drain plug is on a 2003 fxdl
Old 07-11-2009, 06:19 PM
wilcher's Avatar
wilcher
wilcher is offline
Not sure but it might be on a tube hanging down that is on a plug and hose clamp to hold it there. Check that.
Old 07-11-2009, 06:20 PM
archergodwin's Avatar
archergodwin
archergodwin is offline
Which oil?
Old 07-11-2009, 08:10 PM
bagman1's Avatar
bagman1
bagman1 is offline
The oil drain is on the side of the pan on the left side. The trans is on the bottom on the right.
Old 07-11-2009, 09:55 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
seniorsuperglideE8 is offline
Received 4,309 Likes on 2,356 Posts
The engine oil drain plug is on left side of of the trans oil/eng oil pan. Using the jiffy stand as a reference look underneath about six inches back, you'll see a hex plug with allen wrench fitting in the head of the plug. The transmission oil drain plug is on the right side with the plug facing down.
Old 07-12-2009, 05:47 AM
jakeots's Avatar
jakeots
jakeots is offline
4th Gear
Default oil plug
thanks for the help
Old 07-12-2009, 05:48 AM
jaysonL's Avatar
jaysonL
jaysonL is offline
Engine oil plug is always on the jiffy stand side on Dynas and Baggers.
Old 07-12-2009, 07:48 AM
Naz_Man's Avatar
Naz_Man
Naz_Man is offline
That's a good way to remember it.... You don't know how many times I drained the trans when trying to change the motor oil
Old 07-12-2009, 09:40 AM
everythingZen's Avatar
everythingZen
everythingZen is offline
Old 07-12-2009, 02:39 PM
jarhead45's Avatar
jarhead45
jarhead45 is offline
always good info to know before hand.. I hate draing my tranny instead of cases. been there done that.
Quick Reply: oil drain plug
