Wide Tire Kit / Signal Relocation
Old 07-23-2009, 09:59 PM
SeeNoSun's Avatar
SeeNoSun
SeeNoSun is offline
Default Wide Tire Kit / Signal Relocation
The HD web site says I need to relocate my turn signals if I have a detachable sissy bar and want to install the Wide Tire Kit.
Has anyone installed this kit without doing this?
From HD web site:
Wide Tire Kit - Dyna® Models
Add the wide tire look to your '06-later Dyna® model. The 180mm rear tire fills out the rear fender to add a menacing look from the back. A simple conversion at your first tire change, the kit includes the DUNLOP®/ Screamin' Eagle® GT502 180/60B17 rear tire and the required installation brackets and hardware. This easy-to-install kit fits with the Original Equipment 17" wheel, and requires no frame or powertrain alterations.
43768-06
IN-STORE PURCHASE ONLY Contact dealer for pricing and availability.
Fit '06-later Dyna® models (except FXDWG, FXDF, FXDSE/2, FXDFSE and '09 FXDB). Installation of Rigid Sideplate Kit P/N 52856-06 on models without saddlebags requires separate purchase of Hardware Kit P/N 53975-06. Installation of Detachable Sideplate Kit P/N 52866-06 on models without saddlebags requires separate purchase of Hardware Kit P/N 53974-06.
Old 07-23-2009, 10:17 PM
ackman1968's Avatar
ackman1968
ackman1968 is offline
My understanding is you do not need the kit. There are several people on hear that have done the swap with out it. With any luck one of them will chime in.
Old 07-23-2009, 10:37 PM
archergodwin's Avatar
archergodwin
archergodwin is offline
Ditto... as I understand it, if you have the detachable sideplates, you basically have the fender/wiring part of the kit. I'm not sure about any wheel spacers or stuff like that.... I have a 170 on the back of mine, and it fits with plenty of room.
Old 07-23-2009, 11:22 PM
JaronB's Avatar
JaronB
JaronB is offline
Agree with the rest above, there are several that don't use the kits because the side plates just smash the wires against the fender so they don't stick out. If you have your wires nice and tight you won't need the kit. I just installed the detach kit last week and I kept the stock brass plates on the inner fender and just used the hardware. I got a 3 inch bolt and a 1/4" chrome spacer from the hardware store and here's what came out of it. I also have a touring rear turn sig bar on the way so I'll put the sigs on the back of the fender under the tail light.
Old 07-24-2009, 02:43 AM
jmpancoast's Avatar
jmpancoast
jmpancoast is offline
Here are a couple diagrams which come with the kit. You can see where the main purpose of the kit is to secure the signal wiring as close to the inner fenders walls as possible.
I had problems with my 160 tire tearing up wiring once I lowered the rear. To correct this once I went to the 180, I moved the rear signals and wiring out of the way all together.
Old 07-24-2009, 03:20 AM
Tat2u's Avatar
Tat2u
Tat2u is offline
i'm fitting a 200 soon on a 5.5 rim, gonna move my rear sigs right near the top shock mount somewhere, prob pull of the shock this weekend and fab something up
Old 07-24-2009, 05:13 AM
Delmarksman's Avatar
Delmarksman
Delmarksman is offline
JM, I really like the FLH type turn signals on your bike. Do you have any P/N's for that setup?
Old 07-24-2009, 05:54 AM
jmpancoast's Avatar
jmpancoast
The set-up I used was the Harley 68615-04.
Old 07-24-2009, 07:56 AM
SC-Longhair's Avatar
SC-Longhair
SC-Longhair is offline
This is one of those topics that has been beaten to death. Please use search function.
Old 07-24-2009, 07:59 AM
SC-Longhair
I've asked this over and over. I have detachable backrest. I did not get any parts resembling anything in the wide tire kit. I don't see where one would affect the other either.
Quick Reply: Wide Tire Kit / Signal Relocation
