Inner primary leak disaster! Now whats the fix??
98 FXD Dyna.
I realize now why the inner primary was leaking on the back side between the inner primary and the engine! I thought the o-ring or gasket just needed replacing. I was wrong. Somehow, the previous owner broke 1/2 the diameter of the o-ring lip on the engine case itself. It looks as though they tried to silicone the lip bacl onto the case, then use an o-ring.
I definately dont think an oring is an option anymore. I do have the 1/2 diameter lip for the crankcase still, but I dont see a leak proof way of glueing, siliconing, etc then being able to use the oring.
Is there someway I can seal it with gasket? Is there maybe an older style inner primary that used a gasket I can purchase? Do I epoxy the inner primary to the engine case??
Thanks for the help!!
if you still have the pcs and you want a fix other than a tear down over the winter lets say.
You have some options if your good with your hands and tools that pcs could be put back in but silicone won't do it.
Your going to need some JB weld or some very good two part epoxy and a steady hand. If you keep the epoxy or JB out of the oring area and more on the outside you won't have to buff the oring area much and should get it to seal up.
If you get the good liquid two part epoxy that stuff will harden up so hard you almost cant dremel it out.
This would work until you decide to tear it down. I have used this stuff on alot of things in industry and on cars if done right and the area cleaned good its some tough stuff.
I'd give the epoxy a try first though. I've seen the same thing work in other areas, and fortunately the lip in question is not a load bearing member. You just need it to stay in place.
Hi guys,
Thanks for the replies. I actually found this and was going to give it a try first, for what its worth....
https://www.denniskirk.com/jsp/produ...fCatId=&mmyId=
Seems its not all uncommon on these Evos anyways. This basically eliminates the need for an Oring and uses as gasket. Its halfway thru the riding season....worth a shot anyway.
Hi guys,
Perfect!
