andrews 54 cams
They are not a bolt in. You'll need to change springs.
http://www.andrewsproducts.com/PDF_f...ainCam0708.pdf
I would email Andrews and ask them. I have found conflicting info on the 54s. Don posted from the catalog that says Hi Lift springs, but I got an email from Gary Wallace, Andrews tech, that stated they can be run with stock springs...
Man if you are tearing the motor down to do the 103 scratch together the coin to send the heads out to be worked. I wish I would have done this the first time (tore the motor down twice in two month).
i didnt tear the the bike down to do the big bore kit i did it to have the the rocker boxes powder coated and i figured i would go ahead and put the cams in now since its tore down anyway. i called andrews and the tech said he recommends using the 54h cams but he didnt say anything about using adjustable pushrods?
