Will fiberglass packing remain after stock baffle removal?
Guys, when you remove the stock baffles, is teh packing still held in by a secondary baffle? I know on the old mufflers the center baffle was held in by a weld. After you removed that there was another baffle that sadwiched the fiberglass backing between it and the outside exhaust wall. I'm just wondering if removing the baffle is also going to cause the fiberglass packing to come out.
Anyone have pictures of removed stock baffles?
From ackman1968
Removed
Thanks guys,
Andrew
From ackman1968
Removed
Thanks guys,
Andrew
Stock baffle on what? I removed the baffles from my 09 SB and the fiberglass is stuck to the inside of the pipe. The stock baffle had the wire mess welded to the baffle to keep the fiberglass from blowing out. I removed the fiberglass and reinstalled the baffle. So on the SB if you remove the baffle and run it, it will eventually blow the fiberglass out.
In the tapered muffs, the heavy steel mesh used to shield the glass packing is welded to the inside of the muffler cans, so you can remove the baffles and the glass packing is still held in place. On the SB and FB mufflers, the steel mesh is welded to the baffles, so when you pull them out there is nothing left inside the muffler can except the fiberglass packing with nothing holding it in or protecting it.
