Fat boy or Roadking front-end on a 05 Dyna Lowrider
I used a 2005 Fat Boy front end on mine and to make the lock work I fabbed a plate that I bolted to the lower tree. I figured out the distance between the plate and the fork lock and cut a bushing so it would slide in. From here it was just pure dumb luck. I started with the intentions of tacking the bushing to the plate incase I missed but for some stupid reason welded it solid. Got lucky and it was just right. I have a picture in a thread I posted on the conversion, some of the info will help you but some will not. There are differences from my 06 to the earlier bikes so keep that in mind as you look at this.
https://www.hdforums.com/forum/dyna-...i-project.html
