Dyna speedo relocate done !
Finally finished it up. I relocated my speedo for under $75 dollars and kept a stock look (kind of) Here is how it came out. Cleared the stock tank height with very small spacers. All I bought was some fiberglass, wrinkle paint, The bracket (#7 from below diagram), grommet (#6 from below diagram), two spacers and two longer bolts. No re-wiring required and all wires are long enough. I did drill another hole in the stock backplate to run the wires out of.
Here are some pics and links from other post I used for ideas:
I also fiber glassed a cover for the wiring using the stock piece.
Heres the how to: Thanks Collide
https://www.hdforums.com/forum/sportster-...version-5.html
Thanks danfino
https://www.hdforums.com/forum/dyna-glide...ml#post4994281
Thanks danfino
