Fxrh?
Fxrh?
I got a seat from a friend for a Dyna and it says FXRH on teh bottom with part number 80313. It is a corbin that is camel color and is made to hook to a hinge and open sideways if that makes sense. He wants me to sell it but I do not know what it fits. He said 91 FXR or something but I know nothing about fxr's. Googled it and couldn't find any info. Help would be appreciated. Pics to come tonight or in the morning. Thanks...
FXR was a super glide in 91
Model FXR Description:Super Glide Productionyear:1991Engine:EvolutionDisplacement:13 27 ccm (81,00 cui)Horsepower:67.00 (48.9) @ 5200Torque:114.00(11.6 / 83.9) @ 3600Compression:8.5:1 Bore/stroke:102,0 x 102,0 mm (4,0 x 4,0 inch) Valves pr cylinder:2 Gears:5 Final drive:Belt Weight: Weight dry:261,1 kg (575,4 lbs) Front tyre:100/90-19 Rear tyre:130/90-16 Front brake:Single disc Front brake diameter:292 mm (11,5 inch) Rear brake:Single disc Rear brake diameter:292 mm (11,5 inch) Top speed:160 km/h (99,9 mph) Fuel capacity:16,0 litres (4,20 gallons) Reserve:2,0 litres (0,40 gallons) Fuel system:Carburettor Starter ignition:Electronic Seat height:660 mm (26,0 inch) Length:2325 mm (91,6 inch) Wheel base:1602 mm (63,1 inch) Ground clearance:137 mm (5,4 inch) Numbers produced:2014 I am sure if you give Corbin a call they will tell you what models it will fit
