2010 Dyna WG Oil level
I took my bike (beautiful Redhot Sunglo by the way! Makes me think of, "Well there she is buddy, a gleamin in the sun, there to greet a workin man when his day his done... ) in for the 1000 mile service at a local shop and they did all the tightening and adjustments, etc. and of course changed the oil. The specs called for three quarts of oil and so they drained it, replaced the filter and then put in three quarts of oil. When I got home, I checked the oil and it was reading almost a quart high on the dipstick! I called them back and said, "Dude, you put 4 quarts of oil in my 3 quart bike! Why?" They replied saying, "We only put 3 in."
Therefore I rode back in and watched them drain three quarts (actually just under due to the oil filter volume) back out of the bike into a clean oil pan and then saw them dump the three quarts back into the bike (so they proved it to me). The only two things I could think of were 1) the dipstick was wrong, 2) the bike holds less than 3 qts. They checked with HD who said three quarts so that option was out. But what donned on us was that the 2010 FXDWG has been lowered a bit this year and HD used the same jiffy stand. Therefore the bike sits higher (doesn't lean as much when on the jiffy stand) and therefore shows extra oil on the dipstick. If you or your shop is filling according to the dipstick, you are not getting 3 quarts and running too little oil in your engine. If you are getting 3 quarts, you should notice it reading high on the dipstick.
Actually, the 3 qt. that HD recommends is for a dry motor and the total capacity. Remember, when drained you won't get it all out.
So far I have averaged anywhere from 2.2-2.4 quarts, with it draining for a good 20 minutes after I warm it up.
Has nothing to do with the bike being lowered. I recommend you put in 2 quarts, check your dip stick and add according. If you over fill it it will be eventually puking out of your air breather, and if yours is stock I bet if you pull of the cover you'll find a nice oily mess in there.
I just went and drained some out (a little too much...now I'm three of the seven squares down the dipstick) I'll get an extra quart tomorrow to top it off with (hot of course)
Thanks for your advice!!!
By the way, I ordered a Mustang Regal Duke seat to replace the stock and am hoping to have a windshield pretty soon. I'm trying to figure out which mini apes to put on...just for comfort. 12" or 10"?
